Camshaft not turning
Old 08-10-2008, 12:52 AM
blueagle
blueagle's Avatar
Default Camshaft not turning
98 Integra stalled - engine cranks but won't start.
I took the valve cover off to check the timing belt- looked "ok"; the camshaft looks like it is trying to move but it is not turning while cranking the engine. I am thinking that maybe the timing belt broke below by the crank pulley??? ...maybe with the belt engage in the teeth on the the two camshaft pulleys and part of the crank pulley - it is possible that it broke? If the belt is not broken, what would cause the camshaft not to turn? Also, are these engine non-interference? (piston won't smack into the valves)
Old 08-10-2008, 08:55 PM
JoePoonani
Lexus Tech y0!!
JoePoonani's Avatar
When you crank the engine the cams don't turn?
Old 08-10-2008, 10:39 PM
TheOtherDave™
Apathy Kills
TheOtherDave™'s Avatar
All B-series engines are interference design.
Valves and pistons can collide (and often do) if the belt fails.
Based on what you're telling us, it sounds like the tensioner has failed and that's what has allowed the belt to go slack.
It's probably time to pull the head and see how bad the damage is.
Old 08-11-2008, 08:26 PM
blueagle
blueagle's Avatar
Default ouch
That is what I was afraid of. I probably have bent valves now. The question is do I spend the time repairing it, or replace the engine with one of those Japanese engines with 50Kmi, or just get rid of it and buy another car???
I'm leaning towards getting another car.
Old 08-11-2008, 08:39 PM
1turbodc2
got boost?
1turbodc2's Avatar
how do u know u have bent valves?? some useful information in this post would help
by the way welcome to HAN!
check the FAQ will answer a lot of your questions.
Old 08-11-2008, 09:59 PM
TheOtherDave™
Apathy Kills
You won't know till you pull the head.
I would not make rash decisions at this point, and I certainly wouldn't get rid of the car at this point.
Also, I've merged your second thread into the first one.
In the future, click the quote button next to the post you wish to reply to.
That way, the discussion is contained in one thread.
Old 08-12-2008, 01:02 PM
Lynxs1981
Lynxs1981's Avatar
If they are bent, it's not a huge ordeal to fix it. Couple of hours to tear down and put it all back together.
