1988 Legend.Window will not go up
Old 08-06-2008, 06:36 PM
bp0123
bp0123's Avatar
Default 1988 Legend.Window will not go up
The passenger window on my 1988 legend goes down but it doesn't go up.The previous owner told me the window did not work.I opened the door and the window switch was disconnected.i connected it and the window went down but when i tried to make it go up it didn't do anything.i can hear the window motor when it goes down but not when i want it to go up.i can tell the window was replaced because there is broken glass on the inside of the door.maybe wrong window was put in?Please Help!!!
Old 09-11-2008, 01:51 PM
grnprman
grnprman's Avatar
check the window harness....or try puttin the power direct to the window...i had the same problem and it was the window harness...it would go down but not up..
Old 11-08-2008, 01:03 PM
jazfe
jazfe's Avatar
Have you tried the other switch for the passenger window? Or even both door switches at the same time.
