Engine swap resulted in loss of power.
Do-It-Yourselfer
Just had an engine swap on my 1996 Integra Special Edition. The swap was for another b18b. I noticed that the new engine has very little power. I have a hard time speeding up to freeway speeds and I can't get up hills very easily. I don't see how the engine could have lost compression with less than 60k miles. When I step on the gas it takes forever for my engine to rev up. What could be causing this, what would be my next step?
Apathy Kills
Is the check engine light on?
If so, have you pulled the codes?
Did you get all the ground straps connected properly?
Is the fuel pump producing sufficient pressure?
Is the ignition timing correct?
Have you done a compression test of the new motor?
I can go on..... h:
I can go on..... h:
v-card member alpha
Sounds like maybe the ignition timing is retarded, as suggested, might be set to TDC (white mark) instead of xdegrees BTDC (red mark) like it's supposed to be. My throttle response went way up once I set my timing correctly.
Do-It-Yourselfer
Well, I paid a professional Honda shop to do it so I have no clue whether or not any of that was done. I assume they set the timing correct but I don't really have a way to check. No CELs, my car used to have the CEL on all the time before the swap.
v-card member alpha
If you know someone with a timing light, you could borrow it. Otherwise, I purchased mine for $15 on ebay.
I'm not saying your timing is off, it was just a guess. If it were set a TDC or close to it though, a normal side-effect would be that at low rpms in a tall gear like 4th or 5th, if you floor it and then slowly let up on the gas pedal, the acceleration will actually pick up just a bit as you begin to give it less gas. Also, the distributor would be cocked pretty much all the way towards the firewall.
Apathy Kills
You paid a shop to the job right; take the car back, let them diagnose it.
Do not tinker with it in the mean time.
Ask them to confirm that the timing is set correctly and if that doesn't fix things, ask them to run a compression and leakdown test to get a sense of the motor's health.
Do-It-Yourselfer
Then that's your first step.
Apathy Kills
It's remotely possible, but again... it is better for them to follow up on their own work.
exactly, if you do anything as far as replacing things then they aren't liable seeing how the problem could have come since you did it. Since they can't drive it the way it was when they last saw it could come down to a simple "it must have been something you did, it ran fine at the shop after installed"
