rough idle?
Old 07-23-2008, 03:37 PM
facebizz
facebizz's Avatar
Default rough idle?
I have a built LS engine that has recently begun to idle rough. It was tuned using Hondata S100 a year ago and has run as expected since then. Could this be a vacumn line, idle valve or just time to re-tune?
Build included ITR pistons, new valve train with Crower 404 cams.
Thanks,
Old 07-23-2008, 06:47 PM
TheOtherDave™
Apathy Kills
TheOtherDave™'s Avatar
Re-tune should be the last step. You'd get a CEL indicating that the ECU had failed the self-diagnostic at startup.
Check for vacuum leaks (PCV, evap emissions, etc.); while you're in the neighborhood, inspect the IACV.
Old 07-23-2008, 07:04 PM
facebizz
facebizz's Avatar
Thanks for the help!
