Rubbing Sound When Driving - Not the Brakes
Dear All,
When I drive my 96 Integra LS, 157k, there's a wooshing, rubbing sound coming from the front passenger side tire. Thinking it was an issue with the brakes, as I've had some slider pins seize on me before, I changed both the front brake pads and rotors. The car was in need of front brakes anyways, so at least that's done. The wooshing, rubbing sound still remains though.
Interestingly, when I turn the steering wheel to make a right-turn, the sound stops. The second I straighten the steering wheel or turn left, the sound returns.
I know this was a bad idea, but I also put the car in drive while it was on the jacks. I still heard the wooshing sound, so I don't think it has anything to do with the tires, which are only 6 months old now.
What else should I check?
Thanks.
Thanks.
CV joints/axle/driveline related.. pretty darn sure. the steering wheel to the right part was a good hint.
i could still be wrong tho.
DB Squad
Integra Forum Moderator
DB Squad
Hmmm. Do you know how I'd check the "CV joints/axle/driveline" or any ways to test what part is failing. From a visual inspection, I don't see any broken or leaking boots or dry rotted bushings. I'll spend some more time looking through my helms manual. I have never done any work with suspension and steering.
One thing I might do tomorrow is check the passenger's side brake caliper (the wooshing side) for a sticking piston. I did notice the piston was more difficult to push in than the driver's side when I did the brake job.
If it was an issue with a sticking piston though, why would turning the steering wheel slightly to the left cause the problem to disappear?
With an old car that's been problem free for a year, I guess it was time for multiple issues...
Thanks for any thoughts or help you might have.
Thanks for the post, but all the plastic is properly secured so that it doesn't rub on the tire. After searching the HAN forums some more along with Google, I think my issue is the wheel bearing.
With 157k, this would seem to make sense, especially with the noise disappearing when turning. What do you guys think?
You could jack up the front end, grab the front wheel at the top and bottom and try to wiggle it. If it moves or you hear it kinda click, then the bearings need to be replaced. You don't need to yank on it, just slightly back and forth.
Thanks, the front passenger side does wiggle (tires off) side to side a little bit. Looks like it's time to replace a wheel bearing!
