thinking of buying
07-21-2008, 07:17 PM
7M-GTE!!!! "U-BLOC BITCH"
thinking of buying
ok so heres the deal just went and looked at a 93 integra and the alinment was off pulls to the right. The guy claims it started doing it one he put the coil overs on could this be the case? what are some of the causes of bad alinment?????
07-21-2008, 07:23 PM
the winter rims and summer rims are all good?
07-21-2008, 07:32 PM
Elaborate on suspension setup... Shocks, coilovers, etc.
Chances are it needs an alignment, have the toe set to zero.
07-21-2008, 07:36 PM
he told me it they are coil overs stock shocks with shity bomz springs .....could it be like a an axle or something
07-21-2008, 07:38 PM
you have already answered your own question. all you have to do is look now.
07-21-2008, 07:43 PM
i had to drive 1.5hrs to see the car its not with me now....all iom asking is what thins cause bad alignment.....
07-22-2008, 04:49 AM
åhhhhh
any wear or shock to suspension parts can cause bad alignment...
even simple things like a worn tire.
07-22-2008, 08:01 AM
The deer had to die!
Shitty aftermarket suspension installed? check.
There's your problem.
07-22-2008, 09:52 AM
RB does men
07-22-2008, 12:11 PM
i would avoid this car. are 2nd gen integras hard to come by in your area?
