aem cold air intake
Old 11-20-2002, 03:10 PM
jordan88
jordan88's Avatar
Default aem cold air intake
hi, i have a 98 civic ex coupe, i just installed an aem CAI with the bypass valve, for some reason, the pipe that goes down the hole is touching the edge of the hole. does anyone why? is it suppose to be like this or did i installed incorrectly?
thanks you!!
Old 11-20-2002, 03:18 PM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
Default Re: aem cold air intake
thanks you!!
Mine did that ('95)... I just put some rubber on the pipe so it wouldn't rub through.
not much you can do.
Old 11-20-2002, 03:52 PM
Tirod
Tirod's Avatar
that is fine... every one i've seen has touched somewhere
Old 11-20-2002, 05:49 PM
1999civicEX
9" member
1999civicEX's Avatar
i dont have an aem and mine does the same thing. Obviously, if you pay 200+ dollars for it, you want it looking good, so id put electrical tape or something around the hole, and secure the cai.
Old 11-20-2002, 05:52 PM
westcoaststyle
YOu can also cut the whole a little bigger too.. or file it down or something. Just a couple of ideas.
Old 11-20-2002, 06:07 PM
b00gers
b00gers's Avatar
try to adjust it at the rubber ring thinys. if you let it rub, the vibration from the engine will make a groove in them....its not pretty.
Old 11-20-2002, 06:16 PM
westcoaststyle
Ya, mine made the same groove.
Old 11-22-2002, 02:43 PM
jordan88
jordan88's Avatar
can i still use it if it makes a groove like this?
i tried to readjusted, but there is so little room, anywhere i placed hits something. so what else can i do, should i just leave it?
thanks you!!
Old 11-22-2002, 03:46 PM
b00gers
b00gers's Avatar
wrap it with tape. the groove wont mess anything up until it turns into a whole. i wonder how that would sound.
Old 11-22-2002, 04:31 PM
Tirod
Tirod's Avatar
plug a breather in 'er!
