Searching for DIY for bezel/panel removal of radio/lighter
Old 07-13-2008, 04:36 PM
CDelgado220
CDelgado220's Avatar
Default Searching for DIY for bezel/panel removal of radio/lighter
Sorry to post here but I couldn't post this in DIY section. I'm searching for a DIY to remove the radio/manny tranny/lighter bezel to fix my loose lighter problem. I have a little experience removing similar bezels but from toyotas & they usually just unclip but I tried removing it and it seems that the climate control, radio , lighter and manny tranny paneling/bezel is all one. Anyone have any clue or DIY's that would help with pictures so I can have a picture I would greatly appreciate it.
Old 07-14-2008, 09:39 PM
Icon Of Sin
Icon Of Sin's Avatar
what year car?
Old 07-17-2008, 07:02 PM
CDelgado220
5th gen 1996 Accord Wagon LX 5spd. I'll post pics tomorrow
Old 07-17-2008, 09:06 PM
Icon Of Sin
Just to take a stab maybe its like the 6th gen, screw behind the clock and two on the bottom of the console
shouldnt be too hard to tell from the pics tho.
Old 07-22-2008, 03:33 PM
CDelgado220
This crack was from me trying to pry thinking it had clips
I tried removing individually but the console is one entire piece & ALL I need is to fix the lighter.:sad:
Old 07-22-2008, 05:25 PM
VPUPPY
VPUPPY's Avatar
Good luck: http://installdr.com/InstallDocs/Honda/Accord.html
You can remove your shift knob by unscrewing it. I would do this first, then follow the directions.
Old 07-22-2008, 08:12 PM
CDelgado220
Thanks that definitely looks useful.:rockon: I'll give a whirl this week
Old 07-22-2008, 10:07 PM
stereo
stereo's Avatar
first you have to pull the cup holder theres 1 screw to the right corner then empty the center storage and pull the access panel theres 2 screws there now the console should pull back and out exposeing the 2 screws on the radio bezel , also theres 1 screw behind the ashtray, pull down the shift boot then unscrew the shifter.. after the bezel pulls out..
Old 07-22-2008, 11:16 PM
Icon Of Sin
hey i have that stereo in my accord it aint bad for 160 bux.
Old 07-23-2008, 06:38 AM
Tedmond
Tedmond's Avatar
oh man, whats with the prying. Im a MECP installer and i have seen worse DIY where ppl broke their whole bezel.
1) open center consol and pop open the cover at the bottom, remove 2 screws
2) remove cup holder insert. there will be 2 screws directly down, 1 to the left top corner holding center consol to the black trim.
3) you can now remove the Whole center consol up the the black trim.
4) after removal of center consol, there are 2 screw holding down the shift bezel on each side. Unscrew shifter knob and SLOWLY pull the trim. it will just unclip.
5) make sure before you do anything electrical, remove the neg terminal of your battery.
