? with Temp gauge
Old 11-18-2002, 05:37 PM
HatchVX
Driving a Turbo 2L Terror
HatchVX's Avatar
Default ? with Temp gauge
When im accelerating and i get to 3-3.5 k on my tach my temp gauge goes from the normal postion(about a 1/4 inch form middle) to Dead bottom what could it be?
Old 11-18-2002, 07:17 PM
inspyral
のんびり~(´ε`)
inspyral's Avatar
Default Re: ? with Temp gauge
Originally posted by HatchCX
When im accelerating and i get to 3-3.5 k on my tach my temp gauge goes the the normal postion(about a 1/4 inch form middle) for Dead bottom what coudl it be?
I don't understand your question. Is your temp starting out normal, and then dropping under accellerartion? Or is it starting low, and then going up to normal under accerlleration?
Old 11-19-2002, 02:45 AM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
I don't understand either :dunno:
Old 11-19-2002, 04:07 AM
HatchVX
HatchVX's Avatar
It starts normal them drops under acceleration
Old 11-19-2002, 05:15 AM
westcoaststyle
sounds like it's losing power... may be bad wiring? that's pretty strange man. Maybe the gauge is going bad? Or even the sensor?
Old 11-19-2002, 05:58 AM
madlow
madlow's Avatar
try using someone elses cluster if you can.. the gauge could have gone bad.
Old 11-19-2002, 06:01 AM
westcoaststyle
Heck, if you've got a bad gauge, you may as well get an EX cluster or Si cluster. EX is VERY easy to get from a junk yard and will cost less than the gauge alone from Honda.
I suggest you try the sensor too. It may have gone out.
Old 11-19-2002, 06:03 AM
madlow
madlow's Avatar
ebay ownz j00!
search: civic gauge cluster
Old 11-19-2002, 08:19 AM
inspyral
のんびり~(´ε`)
inspyral's Avatar
It is winter, afterall. When you're sitting at idle, there's no air passing thru your radiator, so coolant will stay warmer. When you start moving, the radiator gets some air flow, and the coolant cools down. Of course, your thermostat should be holding the coolant in the engine until it raches about 80-90 degrees centigrade...
Old 11-19-2002, 08:41 AM
HatchVX
HatchVX's Avatar
Right now i have a 92 VX cluster in my car.
