b16a swap troubles HELP!!!
Old 07-05-2008, 12:32 PM
genuin
genuin's Avatar
Default b16a swap troubles HELP!!!
ok I did a JDM b16a swap into my 95 rs. Heres the thing I'm using my ls distributor, it starts right up but revs lazy or weak also when i come off the clutch to it barely moves actually crawling the it would pick up and go but still moving sluggish. I checked vaccum,timing,and all plug ups and i get no codes.I have not wired for vtec as yet and still using my stock ecu (p75) .I'm at a loss right now and would like some help Thanks
Old 07-08-2008, 12:01 AM
Spec R
Spec R's Avatar
obviously, try a distributor that matches the particular b16a model you have. theres a good number of b16 variants out there so find out which one you need and go from there.
as far as you using a p75 and not being wired for vtec, i'm sure thats not helping your situation either.
tell us what model b16 you have, and maybe we can direct you better.
welcome to the boards.
DB Squad
Integra Forum Moderator
