Acura 3.2TL-A/C stopped suddenly
Hi,
My Acura 3.2 TL,98 Model with 142k.All of a sudden my Air conditioning stopped suddenly( blower also not working).Can any one help me where it went wrong? Please help
Thanks
Thanks
Lord Vader Moderator
If the fuses are ok, your blower is probably worn and needs to be replaced.
hi drsanku,
On the passenger side, underneath the glovebox, if you get on your hands and knees and stick your head underneath you should she a white plug with 2 wires sticking out of it. You do not need to adjust or remove anything to get access to this plug but it helps if you move the passenger seat back. Do you see it? Good. Unplug it and look to see if one or both terminals are corroded. No? Try wiggling the plug around with the Fan Speed on 5. Does the Fan turn on?
That did it.
hi drsanku, thanks a lot. That did the trick. Thank heavens for these forums. I located the power cord for the blower motor. Dis-connected it. Plugged it back in. And wiggled the cable with the A/C on. And it cut on. Thanks a lot.
