Odd Screeching Sound. Steering?
Old 06-27-2008, 10:19 AM
94civicEX
I got worms.
94civicEX's Avatar
Default Odd Screeching Sound. Steering?
After starting up my car, when I turn the first couple of times, I get this random screeching sound. It only last for 1-2 seconds then it's gone.
Does anyone have any ideas? I'm hoping it's just the drive belts.
99 Integra GSR
06 TSX
duck squad member #00003
Old 06-27-2008, 12:28 PM
reno96teg's Avatar
probably one of the belts. is your a/c on when you're starting the engine? if not, it's probably the alternator belt. stand over the engine bay and have someone start the car.
see if you can hear where it's coming from.
Old 06-27-2008, 01:21 PM
jesusublime99
jesusublime99's Avatar
I had those same symptoms, my PS belt was a little loose.
Old 06-27-2008, 03:48 PM
94civicEX
I got worms.
94civicEX's Avatar
I always turn the AC off before I start, so it's never on . It doesn't squeak when you start it. It's after it's started and you start driving and steering. It goes away after 5-10 minutes. Probably after whatever it is has heated up.
Thank you, I'll check it out.
Please note that it is not the typical squealing that you hear from cars, rather a short screech.
99 Integra GSR
06 TSX
Old 06-27-2008, 03:54 PM
dubcac
I
dubcac's Avatar
PS or ALT belt
Old 06-27-2008, 05:42 PM
reno96teg's Avatar
i missed the part where you said you turn a couple of times. h:
it's probably your p/s belt. try increasing the tension, unless it's obviously under proper tension in which case you may need to replace it. hopefully it's not the pulley itself.
Old 06-29-2008, 10:20 AM
whatinthe
The Duke of Earl
whatinthe's Avatar
Tighten ur belts and, with the engine running, soap the contact side of the belts. U a bar and b sober
Old 07-01-2008, 05:04 PM
Spec R
Spec R's Avatar
yep, a loose belt tends to make noise.
i had the same problem in the 240sx, i just replaced all the belts.
DB Squad
Integra Forum Moderator
Old 07-01-2008, 06:13 PM
94civicEX
I got worms.
94civicEX's Avatar
It's getting more annoying. Once the car is warmed up, it goes away. Although it is 100F outside, lol.
I think it might be the Alternator Belt now.
What are the standard intervals for drive belts?
99 Integra GSR
06 TSX
Old 07-01-2008, 07:05 PM
Spec R
Spec R's Avatar
dont know, on your car it should be the same as the timing belt, which is 95k or so
DB Squad
