Help Cel 4
Driving a Turbo 2L Terror
Help Cel 4
OK I took off my old CX head and replaced it with a DX one. I had to change the ECU b/c the CX gas curve was wrong. I got a 93 DX ecu and i still have the CEL. But if i put the CX one in the CEL goes away. I already replaced the Distributer, B/c thats where the Crank Angle Sensor is. What could it be? A bad ground maybe or like a bad coil pack? Any help will be apriciated. I want to see if you guys can help b4 i take it to honda for a dionogtist(sp) test. BTW the CEL is Crank Angle Sensor Curcuit.
wooooo woooooooooo
I know with some swaps like that, you have to really retard the timing for it to work properly. May want to give that a shot. Or you could have gotten a bum dist.
The oil in the tube should be unrelated, but sitll needs to be fixed. That should just be the ring on valve cover.
