acura98tl trans problem
Old 06-21-2008, 07:36 AM
franco542
franco542's Avatar
Default acura98tl trans problem
I Also Have Problem Error Codes Tps And Trans Code One Tech Said Cant Find Problem But Is Not Trans Or Tps Or Computor Hard Shifts And Runs Ok Then Later Wont Shift Out Of 1st
Also Changed Oem Thermostat
Old 06-21-2008, 10:52 PM
AcuraTL
Lord Vader Moderator
AcuraTL's Avatar
Try again, explain your problem so anyone reading it can understand.
Old 06-22-2008, 11:18 AM
franco542
franco542's Avatar
Default 98tl trans problem
bought 98tl as is shifted hard but thought all is was was bad trans mount and motor mounts . I drove it for two days then would not shift out of 1st gear.Acura tech said not trans,tps sensor or computer.Next day may or may not shift out of 1st untill warms up
Old 06-28-2008, 02:22 PM
franco542
franco542's Avatar
trans wont shift out 1st if idissconect battery and reconnect it will shift fine for awhile then return back to not coming out of 1st. error codes are p1122,p0135,p0141,p0700,p1790 Can any one help
