Go Back   Honda-Acura.net > Tech Forums > Audio & Security
Audio & Security Troubleshoot wiring problems and get equipment suggestions all in one place.
Thread Tools Display Modes
Old 06-20-08, 02:36 PM   #1
Audiolink
Bose Audio System
Anyone having a problem adding after market electronics to their Bose System?
Let me know I can Help!!
      Registered and logged-in users don't see this ad!
Register your free account today.
Audiolink is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-29-08, 09:32 AM   #2
corkss
I had a camaro once with a factory bose sound. For some reason I want to think you can't connect anything other than bose up to em, unless its a head unit... what you having trouble with?
03' Accord ex
94' Integra gsr
corkss is offline   Reply With Quote
Old 06-29-08, 03:18 PM   #3
MadScientistMat
I also had a Corvette with them - the best way to deal with the Bose system on a Corvette is to rip out the whole thing. It ran at a strange voltage level with mini-amps at the speakers. It is also possible to add a sort of voltage converter to put non-Bose speakers on one with a separate amp.
Not all Bose systems are that weird, though.
MadScientistMat is offline   Reply With Quote
Old 07-22-08, 06:39 PM   #4
jason.tyrone
amp rca in 02 tl w/bose
m tryng to hook up a aftermarket system to my 2002 TL i have the power cable in and the remote wire in but how do i get rca to the aftermarket amp?
jason.tyrone is offline   Reply With Quote
Old 07-23-08, 09:42 AM   #5
Tedmond
use a Low output converter, also known as HI-to-Low converter. it changes high level speaker outputs to Lowl lever RCA outputs. this will run you 15 - 30 dolalrs depends on where you buy.
MECP Certified
Alarm/Car audio wiz
Tedmond is offline   Reply With Quote
Old 07-25-08, 05:44 PM   #6
Travis@DICE
Banned
Send a message via Yahoo to Travis@DICE
Yes there are your basic hi to low adaptors that you can get for 15 to 20 bucks or so. There are also higher quality ones that you can get that will work alot better and also give you alot better audio sound. I would recommend looknig into some of the interfaces from Audio Control. These also give you a line driver as well. Most the time when you convert your speaker wires to RCA you get about a volt to 2 volts of signal. The Audio Control pieces you can get those and have up to 13 volts of signal and level match it to what your amp can exept.
The great thing about stronger voltage is that it will give you a cleaner audio signal into the amp so you will be able to get a cleaner sound from your speakers.
Travis@DICE is offline   Reply With Quote
Old 08-01-08, 09:38 PM   #7
Tedmond
travis is right. however if you mismatch your voltage input, you will burn the amp low freq inputs. often they are rated for 4.2volts max.
MECP Certified
Alarm/Car audio wiz
Old 08-04-08, 02:36 PM   #8
Travis@DICE
Banned
Quote:
I do know that most amps can take an average of about 10-12 volts of signal input. This is you average amps like Alpine, Kenwood, Rockford Fosgates, JL Audio, and amp companies like this. When you look at the owners paperwork of the amp that you are useing it will tell you what the amp can take.
Old 08-09-08, 06:30 PM   #9
Tedmond
yeap, most are 4v but higher end ones have large inputs voltages so check the manual and make sure before you burn something
MECP Certified
Alarm/Car audio wiz
Old 08-30-08, 11:20 AM   #10
mattheo1005
upgrade oem bose sound system
i have 2006 mdx acura with bose and dvd navigation system my question is how can i upgrade the cd changer that would not interfere the function of the navigation coz i wanted to play an mp3 cd but it wont play to my stereo
mattheo1005 is offline   Reply With Quote
Old 09-01-08, 02:03 AM   #11
Travis@DICE
Banned
Quote:
Is the question you trying to ask how to upgrade the indash 6 disc changer to play mp3 disc?
Or do you have an external cd changer?
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
