90 Integra RS Wont start after shut off... Wait. Then starts.
Old 06-09-2008, 09:50 AM
ENFORCER
ENFORCER's Avatar
Default 90 Integra RS Wont start after shut off... Wait. Then starts.
So ive had this happen once before to me. The car is running fine. I park it and shut it off. Come out 5 mins later and try to start and it just keeps cranking over but never kicks. Wait a little while (amount varies) and it usualy starts back up no problem and then drives fine. The last time this happend was 2 months ago.
My guess..... wont start because lack of fuel. It was noisy where i was so i couldnt listen to see if the fuel pump kicked on when the ignition was switched to "ON". Anyone ran into this before. Its totaly random when it happens....
Old 06-17-2008, 12:45 AM
mechdisinclined
mechdisinclined's Avatar
yes this happens to me all the time. but as my screen name references i know not how to fix, i have been able to disconnect the battery and it will fire imediatly. very confused?????????
Old 06-17-2008, 02:49 PM
2001TEGGSR
2001TEGGSR's Avatar
These problems are difficult to diagnose. Check the fuel and ignition systems as the manual describes.
Google Honda hookup manuals for a helms in PDF format.
Old 06-20-2008, 01:07 AM
jdm_type r
jdm_type r's Avatar
could be your alternator same thing happened to me changed it out and it worked perfectly
