want to buy but oh soo confused
I want to use some stiffer springs for my coil over set up, i was told the straight springs from spoon are good. Their not that expensive and its spoon! My only problem is getting the right setup from the grid they provide. I'm not sure if they are talking about the spring load or what, anyways here it is.
http://www.spoonsports.us/catalog/pr...ightSpring.htm
STRAIGHT SPRING
8kg/mm
Straight Spring - - 51400-08K msrp $78
10kg/mm
Straight Spring - - 51400-10K msrp $78
12kg/mm
Straight Spring - - 51400-12K msrp $78
14kg/mm
Straight Spring - - 51400-14K msrp $78
16kg/mm
Straight Spring - - 51400-16K msrp $78
18kg/mm
Straight Spring - - 51400-18K msrp $78
20kg/mm
Straight Spring - - 51400-20K msrp $78
22kg/mm
Straight Spring - - 51400-22K msrp $78
24kg/mm
Straight Spring - - 51400-24K msrp $78
What should i grab
STRAIGHT SPRING
8kg/mm
10kg/mm
12kg/mm
14kg/mm
16kg/mm
18kg/mm
20kg/mm
22kg/mm
24kg/mm
What should i grab
Apathy Kills
They're talking about the spring rate... i.e., how many kilograms of force will compress a given spring one millimeter.
For comparison, the Tein coilovers I use consist of a 8kg/mm spring in front and a 6kg/mm spring out back.
I would consider that the limit for a daily driven DC Integra that doesn't see much track time.
Also, you need to match the damping rate of your shocks to the spring rate you choose to run.
As you shop for dampers, research the recommended spring rate for the model you are considering.
Also, read through the suspension section of the Integra FAQ, if you haven't already done so.
The shocks i already have are koni adj, il check them out to find out whats the recommended spring rate, thanks allot brosky!!
