94 legend gs transmission problem
Old 05-24-2008, 03:59 PM
endofmankind
endofmankind's Avatar
Default 94 legend gs transmission problem
I have a 94 legend sedan gs model. the car shift hard from first to second gear. all other gear shift fine. It doesn't make any noise. Do you know what might cause this and how can I fix it. My friend told me that the trans is control by the cpu. do I need to change the cpu?
please help
Old 05-29-2008, 05:15 PM
ari_one
ari_one's Avatar
The 91-95 Legends are known for rough gear changes from 1st to 2nd, so it depends on how hard that shift is.
Old 05-31-2008, 10:40 AM
endofmankind
Default transmission
its not that bad but still noticeable ..it this something i should not be concerned about or do i need to get it fix ASAP?
Old 06-02-2008, 10:58 PM
ari_one
ari_one's Avatar
If it is just noticeable then it is normal. You could try a simple transmission oil drain and fill with Acura/Honda fluid.
Old 06-16-2008, 07:02 PM
endofmankind
Default thank
thanks for the advice
