thread to replacing axles?
Old 05-17-2008, 08:08 AM
hmgemperor2003
hmgemperor2003's Avatar
Default thread to replacing axles?
does anyone have the tread to replacing front both axles on the 94 acura integra gsr. by the way, how much is it for each axles?
Old 05-17-2008, 05:10 PM
WiseGuyOnCouch
Live, Die, & Drive Fast!
WiseGuyOnCouch's Avatar
cost depends on where you get them from. But either way you'll need 14mm 17mm and 32mm(axle nut socket).
1)take off wheel(19mm) take off axle nut(32mm and impact useful)
2)take loose bottom ball joint bolt(disconnect with hammer/balljoint seperator which ever you have)(17mm if i'm not mistaken)
3)take out bolt through lca(14mm i think)
4)pull axle out of hub assembly, out of transmission(unless long axle then either pull 3 bolts on back of block or remove half shaft) then finagle the axle out.
5) installation opposite of removal
in future just search just about every topic ever has been covered by this forum or honda-tech
