help me [96 Integra, loose belt]
Old 05-09-2008, 03:31 PM
å
åhhhhh
å's Avatar
my car started squeaking while I was driving and it got a lot worse after I heard Something fall. pulled into ã parking lot and one of my belts was Barely hanging on.
during my investigation I found out ã bolt fell off causing ã pulley to come loose in an act of retardation I yanked it out causing my power steering belt to come off. by accident.
now the ac belt is ã Little loose because of the missing pulley. which is now in my passenger seat.
I know this might sound retarded but is it safe to Drive with no powersteering and ã loose ac belt?
thanks
96 teg ls.
sorry posting From my phone.
Old 05-09-2008, 03:34 PM
as long as all that the belts power is AC and PS then you ok
but get it fixed asap
Old 05-09-2008, 03:47 PM
LT
The deer had to die!
LT's Avatar
Your car will survive.
Old 05-09-2008, 06:04 PM
just remove your AC and powersteering unit and belts.
Old 05-09-2008, 06:08 PM
TheOtherDave™
Apathy Kills
TheOtherDave™'s Avatar
Pruned, re-titled and moved to Integra / ITR.
Old 05-09-2008, 08:50 PM
å
åhhhhh
å's Avatar
Thanks for the help guys.. i know i should have been more careful..
would i be able to re-attach the pulley and the belts myself? or do i need special tools for that?
Old 05-09-2008, 09:39 PM
TheOtherDave™
Apathy Kills
I believe the tension adjustment for the PS pump drive belt is built into the pump mount itself. I have yet to replace my PS belt, so without checking my Helms manual, I'm not 100% sure.
In either case, it's not brain surgery. You should be fine assuming you have a decent set of metric sockets & end wrenches.
Old 05-29-2008, 01:13 PM
whatinthe
The Duke of Earl
whatinthe's Avatar
There's a wing nut on top of the ps unit. Loosen the two mounting bolts, with the car not running , and tighten away! Retighten moutain bolts. Robert
