Adult Toys - April 2008
Administrator ☂
Endless Brake Pads For Brembos
New from Endless is its specially designed brake pad compound made just for OE Brembo applications like the Type R's that allows users to take full advantage of what their Brembo calipers have to offer. The all-new SS-H compound-codenamed GT-L during development stages-is a high-performance street pad that doesn't come with the noise often associated with high-performance street pads. The SS-H brake pad offers the best of both worlds: high-performance and complete silence-a set of words that rarely go together.
www.endlessusa.com
Bridgestone Fuzion VRITires
What is the Fuzion VRi? It's an all-season tire that strikes the perfect balance between ultrahigh-performance and style. From the construction and the compounds to the design, the V-speed-rated tire sports an asymmetrical tread pattern worthy of its performance rating by offering awesome steering response, braking, traction and cornering. Fuzion tires feature Long Link Carbon technology, a process that allows the compound to resist microscopic tread tearing due to wear and spiral-wrapped nylon-reinforced twin steel belts for high-speed stability. Despite the Fuzion's directional appearance, it's an asymmetrical tire-meaning it can be mounted on either side of your vehicle. Fuzion VRi tires are offered in a number of sizes ranging from 15 to 17 inches.
www.thefuzionzone.com
Password:JDM Dry Carbon RBC Intake Cover
Password:JDM has done it again. This time they've crafted an exotic, race-inspired, dry carbon intake manifold cover for the '06 and up Civic Si/RBC intake manifold. Like all of Password:JDM's dry carbon pieces that they manufacture, the RBC intake manifold cover has been precision crafted for a perfect fit every time. They've also used a fade-resistant resin during the manufacturing process to ensure each cover will look and function as good as the day it was first installed. Covers fit all '06 and up Civic Si models or any K-series engine equipped with the RBC intake manifold for that matter.
passwordjdm.com
Streetlightz DA Integra One-Piece Headlights
They're here, genuine one-piece headlights for the '90-'93 'teg, direct from StreetLightz. Like all OE products from StreetlLightz, the newly offered DA pieces are genuine Honda-issue, meaning you won't have to worry about fitment or getting clowned for rockin' a pair of dorky knock-offs. Rare is putting it lightly when it comes to brand-new one-piece headlights for the DA but StreetLightz solves that problem. Applications fit all DAs, both two- and four-door models, and are a bolt-on, plug-in job.
www.streetlightz.com
AFE '06-'08 Civic Cold Air Intakes
Advanced FLOW engineering (aFe), an industry leader in performance cold air intakes, filters and exhaust systems has just released their new Stage 2 cold air intake system for the 1.8L '06-'08 Honda Civic. They're offering two systems: the first features a large 6-inch, 360-degree high-flow washable/reusable Pro 5R aFe filter for maximum filtration and flow, the second, the Pro-Dry S filter, is also a 6-inch, 360-degree high-flow piece and represents the new breed of filters that produces increased filtration and flow but requires no oil. Both kits come with a one-piece, 16-gauge aluminum housing to provide a cooler intake charge for increased performance. aFe claims recent testing with the Pro 5R filter's yielded 4 hp at 6,000 rpm, 5 lb-ft of torque at 4,900 rpm and an 89 percent increase in airflow when compared to the factory intake system. Kits retail for $269.41 and $263.53, respectively.
www.afepower.com
Mishimoto Fit Carbon Intake System
Mishimoto is proud to announce a new line of intake systems for the '07 and up Honda Fit, which it says is going to revolutionize airflow into your L-series engine. Hand-laid with highly durable, aerospace quality carbon-Kevlar, Mishimoto's kit replaces Honda's factory issue with a piece capable of providing much cooler incoming air temperatures. These OEM-fitting intake systems feature flared edges enabling the supplied filter to breath larger quantities of air when compared to the more traditional intake systems. Kits retail for $320 and include a four-layer cotton and aluminum mesh high-flow air filter along with all of the components necessary for an easy install. They're even lifetime warrantied to take one last thing off your mind.
www.mishimoto.com
Spal High-Output Fan
Doing a swap? Need more cooling? Check out SPAL USA's new AP90 High Output series electric cooling fans. The AP90 is engineered for maximum output at high-static pressures. Such pressures result when large air masses are forced through single or multi-stacked radiator cores. As airflow becomes restricted by the core's density, a pressure differential is created causing the fan to work harder. The AP90 features a proprietary new curved blade design and is available in 11-, 12- and 16-inch sizes with flow ratings as high as 1,953 cfm. SPAL engineers and manufactures its own parts, including the motor, blades and shroud ensuring that the unit works in harmony. The AP90 features rigid, glass-filled nylon blades, dynamically balanced internally and externally to minimize vibration. All fan motors are sealed and balanced and the entire assembly is high-heat resistant, meaning the fan can be expected to outlive the vehicle in which it is installed.
www.spalusa.com
Photo Gallery: Aftermarket Honda Parts - Adult Toys - April 2008 - Honda Tuning Magazine
Read More | Digg It | Add to del.icio.us
More...
www.endlessusa.com
passwordjdm.com
www.afepower.com
www.mishimoto.com
www.spalusa.com
More...
