Where is the OBD data plug?
Old 04-29-2008, 06:36 AM
Ladyvalvamp
Ladyvalvamp's Avatar
Default Where is the OBD data plug?
Ok I have a 95 Acura Integra and have looked just about everywhere for the OBD data plug but I can't find it or I'm over looking it. Can anyone help a girl out?
Old 04-29-2008, 06:44 AM
GSRRacer95
Fight On!
GSRRacer95's Avatar
It should be on the passenger side kick panel area. Check the FAQ section also.
Old 04-29-2008, 07:06 AM
Ladyvalvamp
Called an Acura dealer and they are telling me there is no OBD data plug that you have to run a wire down the dash? That doesn't sound right.
Old 04-29-2008, 09:45 AM
TheOtherDave™
Apathy Kills
TheOtherDave™'s Avatar
Whomever you spoke to is 100% wrong.
The OBD data connector in on the passenger side of the center console, about 3" above where the floor carpet rests on the raised section of the floor.
Feel along the back edge of the trim piece and you'll find it. There are no other plugs in the area and there are no panels to remove.
Old 04-30-2008, 03:47 AM
Ladyvalvamp
Looked all over and even pulled the kicker panel off and no plug
Old 04-30-2008, 12:48 PM
honura
Seni
honura's Avatar
If you are just looking to get the CEL codes then its right under/behind your glove box on the passanger side. There are 2 plugs there. On has a 3 wire connector with 2 wires on it, thats your ABS plug. There is another 2 wire connector with 2 wires on it thats your CEL plug. They both should be blue.
That a paper clip to the CEL plug and jump the wires.
Long strokes are ten's
Short strokes are one's.
so Long,long,long,short,short = 32 so on and so forth. If you need more help Pm me.
