Disappearing oil
Old 04-24-2008, 08:39 PM
maddog01
maddog01's Avatar
Default Disappearing oil
I have a 95 integra LS DOHC. I am going through 3-4 quarts of oil between oil changes. No puddles left behind. There are traces of slight leaking but nothing that I believe adds up to 3 quarts every 3000 miles. Any ideas?
Old 04-25-2008, 02:25 PM
JoePoonani
Lexus Tech y0!!
JoePoonani's Avatar
How many miles are on the engine? Worn valve seals or worn piston rings could cause oil to burn.
Old 04-25-2008, 07:27 PM
maddog01
maddog01's Avatar
The odometer say 96000 but I am starting to question wether its a rebuilt car that had a clean title.
Old 04-25-2008, 10:23 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
If you aren't leaking it, you are burning it. Like Joe said, oil is leaking into the combustion chamber through the rings or valve seals. Do you get a build up of oil on the rear bumper? Excessive oil consumption is pretty odd at 96k miles.
I would suggest a compression and leakdown test to confirm where the leak is coming from.
Old 04-27-2008, 12:16 PM
thetunersource
thetunersource's Avatar
leakdown and compression time... somethings wrong
Old 04-28-2008, 06:55 AM
Lynxs1981
Lynxs1981's Avatar
Run your finger across the bumper over the tailpipe. If it come off black, you're burning it.
Old 05-18-2008, 07:23 AM
maddog01
maddog01's Avatar
Haven't done a compression test but the bumper is clean.
Old 05-29-2008, 12:36 PM
whatinthe
The Duke of Earl
whatinthe's Avatar
Check ur valve cover. I leak there cuz I need to replace some studs. It doesnt look like much because it gets burnt on the exaust or goes to the back of the motor. Take it to the car wash, let it cool down, and use the engine cleaner. Spend a couple of bucks and do a good job. Then u can find a leak if u have one or u'll just have a brand new looking engine
Old 10-20-2008, 06:43 PM
maddog01
maddog01's Avatar
Haven't got to the compression and leak down test but had car idling for about 15-20 minutes and it looked like there was oil built up on tailpipe. Reved the motor and car was smoking pretty good. Does this still sound like valve stems or would we be leaning towards rings?
Old 10-21-2008, 01:42 PM
Spec R
Spec R's Avatar
i burned that much wellll before 96k miles. i never figured out the specific problem, but i'm sure it was an oil ring problem on cylinder 2 becuase the leakdown results were like 18% when everything else in that engine was around 7-8%
DB Squad
Integra Forum Moderator
