Import Wars Great Lakes Dragaway 08 Point Series
Bracketis Racing Extraōrd
Import War Forum is at www.hondaddy.com/forum more chat an info regarding the racing an car show there.
This is a repost from http://www.greatlakesdragaway.com/in...age=importwars
Also the GLD Main Page can be accessed from http://www.greatlakesdragaway.com/
2008 GLD IMPORT WARS SERIES
ATTENTION RACERS ! ! ! New Class Designations and some New Classes for the IMPORT WARS POINTS SERIES. We have broken the classes down to Dial-in Bracket classes and Heads Up Pro Tree Classes
Bracket Classes
Super Street 15.00 and slower (same as D class) 400# series
Super Mod 13.00 to 14.99 (in place of B & C) 600# series
Super Quick 12.99 and quicker (same as Quick8/16) 800#series
All dial-in classes start with "super" and have even #'s to start the class series. And Dial-In there own times. Breakout disqualification. SUPER QUICK class is an unlimited qualified field; however you must run qualifying to be put on the eliminations ladder. Class run on Sportsman Ladder! If you not not make a qualifying run during the sessions you are disqualified.
SUPER STREET & SUPER MOD Entry Fee $45
Winner $200 - Runner Up $100 - Semi Finalist $50
SUPER QUICK Entry Fee $65 - Must have min. of 8 entries for full payout
Winner $350 - Runner up $150 - Semi Finalist $50
Heads Up Classes
Pro FWD (New Class Rules listed below) 500# series
Pro Outlaw (same as Frantic7/ Import Challenge) 700# series
PRO FWD Rules
Designated for all sport compact front wheel drive vehicles only. Heads up - Pro Tree - 1 power adder only - No motor limitations - No wheelie bars! - No tire limitation - Must meet all NHRA Safety rules for the ET you run. Unlimited field, however you must run qualifying to be put on the eliminations ladder. Class run on Sportsman Ladder! If you not not make a qualifying run during the sessions you are disqualified. The rules are subject to change. We may define things better and modify rules as needed Entry Fee $65 min 8cars needed for payout
PRO OUTLAW Rules
Designated for all sport compact door car vehicles only. Heads up - Pro Tree - No motor limitations - No eight cylinders - No power adder limitations - Must meet all NHRA Safety rules for the ET you run. Unlimited field, however you must run qualifying to be put on the eliminations ladder. Class run on Sportsman Ladder! If you not not make a qualifying run during the sessions you are disqualified. The rules are subject to change. We may define things better and modify rules as needed Entry $65
Guaranteed $1000 to WIN !! Runner up $200
NOTE: YOUR NUMBER WILL BE ASSIGNED AT THE FRONT GATE ONCE YOU ENTER AND PAY INTO A CLASS. THEN FOR THE REMAINDER RACES YOU MUST GIVE THEM YOUR ASSIGNED NUMBER WHEN YOU ENTER A CLASS AT THE FRONT GATE. Remember- Be Patient and Come Earlier! Your tech-in process and front gate process will take a bit longer than normal for the first time. But in the long run it will be faster. The first time you tech-in you can be teched in for the year. Then each race afterwards you will still need to check-in with your tech card at tech so you can be arm banded in.
Points will be awarded as follows:
Attendance 10 pts - You must stage during 1st rd to receive these points. 10 pts will be awarded for every round you win!
Points will be awarded to driver. You cannot Substitute drivers during the season.
Current Points sheets will be posted 3-4 days after the race in the Red Barn.
We have 2 Volunteers who will be assisting in helping answer questions at the track. Prescott Phillips ( The Underdog Green Drag Beetle) will help with Pro Classes.
Jacob Bierer ( The Orange Grand Am) will help the the Super Classes Classes.
Top 5 Finalists for each category will receive Trophies and be invited to GLD's Year End Banquet Held in February of 2009.
Good Luck ! ! !
Thanks to all who put this together, This year's action could be the best yet.
Start turning some wrenches!!! Tick! Tock!
Bracket Classes
Heads Up Classes
PRO FWD Rules
PRO OUTLAW Rules
Good Luck ! ! !
