93 legend shifts hard and lifter noise adj?
i had a new trans put in and it is still shifting hard after 20,000 what can i do?
I have started to get lifter noise after 190,000 miles can i adjust them and if so what are the specs.
The G2 (91-95) Legends are known for rough shifts from 1st to 2nd. When you had the new tranny put in, they did use Acura/Honda fluid right? The engine has hydraulic lifters so no adjustment there, might want to consider GM top end cleaner to clean up built up carbon etc.
