Adult Toys - October 2007
Administrator ☂
HP Racing "Rage" Wheels
HP Racing (305) 629-8977
www.hpracing.com
The HP Rage was designed "with the Drift and tuner street scene in mind." The Rage is offered in gloss black and hyper silver light finish. Sizes and offsets are +40 for the 17x7 and +42 for the 18x7.5.
K&N '06 Civic 1.8L Air Intake
K&N (800) 858-3333
www.knfilters.com
K&N Engineering's Typhoon Intake System for the '06-'07 is a direct performance replacement for the stock airbox and intake tract. Designed to maximize airflow and performance over the stock intake system, it comes complete with a silver powdercoated intake tube, heat shield, hoses, all the necessary hardware and of course, one of K&N's air filters. According to K&N, gains of over 5 hp can be seen from the midrange on up to the fuel cut.
Fidanza Clutch Line
Fidanza (440) 259-5656
www.fidanza.com
Fidanza's performance clutch line now covers the most popular Honda sport compact cars. For daily driven vehicles with mild performance upgrades, Fidanza offers its durable and long lasting 2.1 street clutch. The company's 3.2 clutch features Kevlar buttons and offers more grip and longer life for daily drivers that pack an even bigger performance punch. Fidanza's 4.3 clutch caters to the weekend racer with ceramic buttons to help direct power right into the pavement. Finally, for the all out race car, Fidanza's 5.4 clutch delivers instantaneous power with no torsion damper, no marcel and the pads are made from sintered iron. All Fidanza clutch kits come with everything needed for installation, including the pressure plate, disc, throw out bearing and pilot tool.
'06 Civic Si Clutch Kits
Clutch Masters
(909) 877-6800 www.clutchmasters.com
Clutch Masters just released clutch upgrade kits for the '06-'07 2.0L Civic Si. They are available in the traditional four stages from a 70 to 170 percent increase in clamping force over stock. To complement their line of premium Clutch Systems for the 2.0L Civic, they also have an 8.2 pound Billet aluminum (two-piece, limited lifetime warranty) flywheel. Clutch Masters clutches and flywheels are SFI approved on most race applications.
ST Suspensions
'06 Civic Anti-Sway Bars (non-Si)ST Suspensions (559) 875-0222
www.KWautomotive.com
These anti-sway bars replace both the front and rear stock with solid construction anti-sway bars. The front 1-inch stock hollow type anti-sway bar is replaced with a 1-inch solid construction anti-sway bar. The .450-inch stock solid sway bar is replaced with a .625-inch solid construction anti-sway bar. Sway bar forces are increased 205 percent on the front axle and 155 percent on the rear. All ST suspensions anti-sway bars include high-grade mounting hardware, polyurethane bushings and are powdercoated for a lasting finish.
KONIG Wheels "Feather"
KNIG (800) 501-5567 ext. 1649
www.Konigwheels.com
KNIG recently introduced its latest and lightest wheel, theKNIG "Feather." The "Feather" is an eight-spoke wheel that is offered in gold, Race Silver and black. Available sizes include: 15x6.5 and 16x7 in both four and five lug, 17x7 in four lug and 17x7.5 in a five lug pattern.
Injen Technology '06 S2000 2.2 Cold Air Intake
Injen Technology (866)
944-6536 www.Injen.com
Injen Technology's RD1306 cold air intake system is now available for the '06-'07 S2K. According to Injen, they have seen gains of 11 hp and 8 ft-lb of torque with the RD1306. It is constructed with TIG-welded T6661 aluminum and comes with a limited lifetime warranty.
GEAR-X Final Drives and Close Ratio Gears
Special Projects Motor Sports (714) 998-1258
www.specialprojectsms.com
Special Projects Motor Sports, a worldide distributor of GEAR-X final drives and custom close ratio gear sets for Honda performance vehicles, believes that they have the finest quality forged steel gears on the market today. According to Gear-X, they are up to 30 percent stronger than OEM and can withstand "the pounding that real motorsports can generate." A wide range of final drive ratios has been selected to suit a variety of racing requirements and is available for most Honda models. GEAR-X also offers eight different B-Series close ratio combinations for drag, street and road race applications. All GEAR-X products meet or exceed OEM specifications and are fully tested in-house.
Skunk2 Rear Lower
Control Arms
Skunk2 Racing (951) 808-9888
www.skunk2.com
Skunk2 Aluminum Rear Lower Control Arms for the EP3, DC5 and Honda Element replace your stock arms while retaining factory suspension geometry. According to Skunk2 they are engineered to be stronger and 25 percent lighter than stock. The LCAs feature steel mounting plates to equally distribute the clamp loads and avoid galling and loosening. These arms feature low deflection polyurethane bushings to keep the suspension geometry true, even under the load of race compound tires. They include new Skunk2 bolts and sockets required for installation and are available in JDM Gold and clear hard anodized finishes.
Hondata K-Pro for D17
Hondata (310) 782-8278
www.hondata.com/kpro_d17.html
World leading Honda/Acura engine electronics tuner Hondata, has begun shipping a K-Pro solution for the '01-'07 manual transmission D17 Civic. The K-Pro for the D17 consists of a hardware modification to a donor K-Series ECU, a specially modified cam timing wheel, plus Windows software that allows you to reprogram the ECU and datalog sensors. Some of the K-Pro's features include: fuel and ignition control by gear, overboost protection, lean protection, ITB support, dual nitrous output, launch control, integrated wideband support, sequential transmission rpm cut, five bar or larger map sensor support for 60 psi and above, closed loop cam angle control, gear based boost control (requires optional control valve) and full OBD2 and Honda scan tool compatibility.
Photo Gallery: Adult Toys - Aftermarket & Performance Parts - Honda Tuning Magazine
Read More | Digg It | Add to del.icio.us
More...
www.hpracing.com
K&N (800) 858-3333
www.knfilters.com
Fidanza Clutch Line
www.fidanza.com
Clutch Masters
ST Suspensions
www.Konigwheels.com
Skunk2 Rear Lower
Control Arms
www.skunk2.com
More...
