Go Back   Honda-Acura.net > Appearance & Cosmetics > Showroom
Thread Tools Display Modes
Old 01-06-08, 01:52 PM   #1
DetroitStyle
New Person here....
Just got it today, and have just put in my DVD player so far. I have coil overs, and stock wheels that will be going on it at some point. Only plans for this are, a tune, cams, maybe boost, loose the black tail lights in favor of some stock ones, and do clear corners, maybe some "JDM" headlights.
Here are some specs on it.
Head:
Stage 2 ported @ polished
Ferrea Valves Stk size Exhaust/intake
New OEM Retainers
New Crower Valve Springs
New OEM Valve seals
New Valve retainers
New OEM Camshaft seals
Fully built Lower end F22b lower end:
Block Hot tanked/ Main bearing journals all line honed
Stk Bore JE 10:1 compression pistons Heat coated on side skirts and piston tops
Shot peened rods out of H23a1 balanced
Chromoly gap less rings
Crankshaft polished/balanced
OEM Rod Bearings
OEM Main Bearings
OEM Thrust washers
OEM Timing Belt
OEM Balance Shaft Belt
OEM New head bolts
OEM head gasket h23B1
OEM Oil Pump
New OEM Knock Sensor
New OEM Oil Pressure sensor
New OEM Oil Orifice
New OEM IAC Valve
NEW OEM Balance shaft seal w/ retainer
NEW OEM Crankshaft Seal
NEW OEM intake manifold gasket
New OEM Exhaust Manifold Gasket W/ 4-2-1 Header
      Registered and logged-in users don't see this ad!
Register your free account today.
DetroitStyle is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-06-08, 02:00 PM   #2
pow_pow
Not likin' the tails, but the JDM headlights would look great. They really make a difference even though they don't seem like they would...
pow_pow is offline   Reply With Quote
Old 01-06-08, 02:09 PM   #3
DetroitStyle
I found some DOT/SAE approved JDM knock offs that I like allot.
But yes, the tails and rims are going.
Old 01-16-08, 05:55 PM   #4
JoePoonani
Lexus Tech y0!!
JoePoonani's Avatar
Send a message via AIM to JoePoonani
Car looks like it's in pretty good shape minus the obvious blemishes.
09 Civic EX - current DD
03 VW Jetta Wolfsburg Edition 1.8T APR tuned - totalled
94 Integra LS - sold
94 Civic Ferio - stolen/raped
JoePoonani is offline   Reply With Quote
Old 01-30-08, 03:35 PM   #5
DarkStarr
First or last baby!
DarkStarr's Avatar
Send a message via AIM to DarkStarr
Looks nice, be sure to past some pictures after you are done cleaning it up.
DarkStarr is online now   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
