Thread Tools | Display Modes |
#1 | |||||||
2003 CL Cupholder squeaking
| Sponsored Links | ||
#2 |
Lord Vader Moderator
First, find out what exactly is causing the noise. Like when you put pressure on certain spot, does the noise go away? Once you find out where it is, you can either tighten everything up or use double sided stick tape and put between 2 panels where the noise is coming from so they don't rub against each other to create the squeak.
Honda-Acura.net Vigor/TL/CL Forum Moderator. Comptech Icebox, Headers, Exhaust, Lowering Springs and Sway Bars. Mugen front grille. Inspire tailamps. MOMO Sport 18 X 7.5 +42 offset. Axxis Metal Master front/rear pad. 2 Polk/MOMO 10" subs, Orion Xtreme 500.4 amplifier and Alpine CD changer. |
#3 |
Sounds like a plan. Usually if a drive my fist into the cupholder it stops. So it must be squeaking betweek the 2 halves of the cupholder in the middle. I guess I'll need to take apart the assembley and secure the two halves together better.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
