Go Back   Honda-Acura.net > Auto Forums > CL, TL, & Vigor
Thread Tools Display Modes
Old 10-29-07, 06:03 PM   #1
mudmanmike2000@
'99 tl dies while driving
Hello every one,
I have a '99 Acura TL with 280,000 miles. The problem I am having is that after driving the car for a while (5 to 20 minutes) the car dies. The car will not restart for 5 to 10 minutes then it will start with no problems.
Here are some details:
-shows no codes
-after it dies the starter will turn the engine over, but the engine will not run.
-Normaly the green key light lights up for a second or two when the key is ignition is turned to the run position. After it dies the green key light does not turn on when the ignition is turned to the on or run position. After a few minutes the light operates normaly and the car starts.
-The ignition switch has been replaced.
Thank you,
Mike
      Registered and logged-in users don't see this ad!
Register your free account today.
mudmanmike2000@ is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-29-07, 07:29 PM   #2
AcuraTL
Lord Vader Moderator
Send a message via AIM to AcuraTL Send a message via Yahoo to AcuraTL
It could be a lot of things, but if I have to guess, I would say it is the fuel delivery that is failing....possibly the fuel pump. But really, if it does not generate an engine trouble code, you better have a decent mechanic to do some diagnostic for you as it could be several things.
AcuraTL is offline   Reply With Quote
Old 10-30-07, 08:05 AM   #3
mudmanmike2000@
I suspected the same thing untill I noticed the key light t functioning properly. I have read that the PGMFI main relay could cause the fuel delivery to fail, but would it also cause the imobilyzer to not work?
I have taken it to the dealer. They wanted to play the parts swaping game. I think that I have enough clues for a good mechanic to solve it. After days of searching the Net I have found a couple other owners with the same issue, but there are no posts with a remedy.
Thank you for your time.
Mike
Old 10-30-07, 06:52 PM   #4
AcuraTL
I am not sure about the immobolizer malfunctioning, it could be the cause but you won't know until you play the swap game.
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
