91 legend -where's the control module?
Old 08-29-2007, 03:33 PM
Oh_My_A_Legend
Oh_My_A_Legend's Avatar
Default 91 legend -where's the control module?
I have fuel and this car will only start when cool outside, once it's hot, forget it. You have to let it sit and then it will start. Someone told me the control module and the fuel are the only two things this could be, I have a control module> don't know where it goes, I'm getting gas, cause when it sits for a while it will start. ???? ANyOne?
Old 08-31-2007, 09:10 PM
ari_one
ari_one's Avatar
Most likely your problem is the main relay, it controls the fuel pump. You can either replace or solder the old one. It is under the lower dash on the drivers side almost on the outside wall. It clearly says main relay on it. The normal symptoms of a bad one are it won't start on when the car is hot.
