Thread Tools | Display Modes |
#1 | |||||||
vtec issues
| Sponsored Links | ||
#2 |
I WANT WINNERS
Is the check engine light on?
03 S2000 / Apexi / ATE / Bilstein / Mugen / T1R / Work || Academy Team 52 / Union Data Pinstripe Team B.O.B.® - Ballaz on a Budget "Hip hop is so wack, the beats are fighting back And I was sent to attack, so I'm following the map" |
#3 |
I missed Sean
Thats the opposite from what should happen, I'm surprised it will even get that high in the revs without needing the cam switch.
I take it you haven't done any head work before this problem occurred? How exactly are you "unplugging" the vtec?
1.8L Acura Integra GSR: Back where it belongs. 3.2L Pontiac Tran-sport Montana: that things about to go. 2.2L Honda Accord EX: Sold to my sister 232CI Mercury Sable: Sold to some lady, by my father, while i was on a camping trip. IMM232 http://imagegen.last.fm/minimalDark/..._vigilante.gif |
#4 |
I WANT WINNERS
I'm assuming he's unplugging the VTEC solenoid, which in of itself should turn on the CEL.
#5 |
There is no cel, and I am unplugging it from the solenoid.
#6 |
It will rev to 8000 with it unplugged just fine, but really does not build power after about 6500. With it plugged in, the vtec kicks in at 6000, and as soon as it kicks in it has hesitation, and doesn't want to go.
#7 |
Does anyone have a pinout for the s2000 computer?
#8 |
No headwork done at all. I hooked up a greddy emanage computer, and the car would not run right at all, unhooked it and now this is the problem I have. I don't know if I hurt something or what happened, but I have it wired back to stock, and have double and tripple checked the wiring, and am pretty positive it is correct.
#9 |
I missed Sean
Hows the compression on the engine?
maybe theres a problem with the valve springs was the engine accidentally over revved in a down shift?
#10 |
compression is fine, and it was not overrevved. Like I said, with the vtec solenoid unplugged, the car runs perfect.
#11 |
I missed Sean
I posted that before I knew that you messed with the electrical, exactly what did you take apart, did you merely unplug the ECU and then put it back?
#12 |
I WANT WINNERS
Have you tried swapping the ECU with a known good one?
#13 |
dubcac sounds like he has the best idea.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
