How to make and install a det can
Old 05-08-2007, 06:30 AM
lkailburn
college kid
lkailburn's Avatar
Default How to make and install a det can
I know this has been covered before but i made a how-to while making my det can so i just thought i'd share. its permanently hosted on my website at:
http://www.lukekailburn.com
The parts
<b>building the engine block side:</b>
-Take your 4-5" peice of copper and using a vice grip or other means, flatten a good 1" to 1.25" section of the pipe.
-Now take 1/8" of the tip and bend it 90*. You are trying to seal off the end of the tube. Drill a hole just large enough for the bolt in the flattened part of the pipe.
-Solder the 1/2" threaded fitting onto the end of the pipe, and also solder shut the flattened bent tip.
-Take some teflon tape and wrap the 1/4" barbed fitting and screw it into the pipe fitting.
Here is what the engine block side of the det can will look like
run your 1/2" hose through the firewall and into the cabin
Bolt the block side of the det can to the block. Connect the hose to the block fitting.
You have an option here, you can:
-T the 1/2" hose and run two lines, 1 to each side of the ear protectors.
-just run the single line to one side of the ear protectors.
I chose to just run the single hose to one side of the ear protectors for simplicity and to save money.
Drill 1/2" hole in your ear protectors
Shove 1/2" of the tubing into the ear protectors and seal it with duct tape. The tape allows you to disconnect the ear protectors and remove the det can when finished. Another option would be super glue or hot glue. this would seal better than ductape but I'll see how this setup works.
An overall shot of the setup
<b>congrats you have successfully built a det can. You can now listen to detonation to help you tune your timing on the streets</b>
enjoy,
-Luke
Old 11-28-2007, 09:25 PM
effilcdar
effilcdar's Avatar
Default det can
And why not just get a knock sensor?
Old 01-27-2008, 07:13 AM
lkailburn
college kid
lkailburn's Avatar
this if far superior to a knock sensor. please search. you'll find an oem knock sensor spits out nothing useful compared to this
-Luke
Old 04-01-2008, 06:35 PM
goldex420
goldex420's Avatar
very creative props
Old 04-06-2008, 11:23 PM
dleccord
dleccord's Avatar
so im guessing you can use this in a bathroom to hear conversations since sound will travel through tubes?
Old 04-07-2008, 11:44 AM
lkailburn
college kid
lkailburn's Avatar
haha oh i love critiques. go build one and tell me what you hear moron
-Luke
Old 04-09-2008, 11:21 AM
IanB
MB4
IanB's Avatar
Nice DIY, I've been meaning to do this for about 6 months now, lol.
Old 02-15-2009, 03:16 PM
fabio16v
fabio16v's Avatar
just one question...whats this for?
thankx
Old 02-18-2009, 04:31 PM
DakarM
DakarM's Avatar
thankx
the idea is you can listen for detonations and change your timing to compensate. it's like a stethoscope for your engine but if you have a stock engine and no way to tune it, then it's use less.
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old 04-07-2009, 07:31 PM
lkailburn
college kid
lkailburn's Avatar
+1 it's a great cheap analog tool to use if you know how.
-Luke
