Go Back   Honda-Acura.net > Auto Forums > Prelude
Thread Tools Display Modes
Old 03-08-07, 09:48 PM   #1
TheOtherDave™
Keeping the faith...
TheOtherDave™'s Avatar
>> Prelude FAQ: Under Construction; Contributions Welcome
As you might guess, we're looking to rejuvenate this forum and get more people in here.
This is an open call to all Prelude gurus and anyone with resources they'd like to share for the benefit of the group.
Ultimately, we'd like to wind up with something similar to the Integra FAQ.
Thanks in advance.
How To: 92-96 Prelude 5th Gen Moonroof Conversion
      Registered and logged-in users don't see this ad!
Register your free account today.
david :: supermoderator
:: HAN Integra FAQ:
Borderline antique, but still useful.
TheOtherDave™ is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-17-07, 07:49 PM   #2
Mkazm83
Snapping bolts
Mkazm83's Avatar
Send a message via AIM to Mkazm83
Finally, someone getting involved in the Prelude forum. Thanks Dave.
5th gen stock radio/AFBS info.
http://bellsouthpwp.net/v/i/vidgamer/preludeaudio.html
Mkazm83 is offline   Reply With Quote
Old 04-15-07, 11:51 AM   #3
Enzorunner
Enzorunner
Enzorunner's Avatar
Send a message via AIM to Enzorunner
i KNOW SOME BOUT THE PRELUDE I HAVE A 89 PRELUDE SI I LOVE PRELUDE AND I JUST FOUND OUT BOUT THIS SITE AND IAM HOPING TO FIND OUT LOTS BOUT MY PRELUDE THANKS DAVE
Enzorunner is offline   Reply With Quote
Old 07-03-07, 04:17 PM   #4
TheOtherDave™
When I made this thread, I was hoping that the forum regulars would all contribute links and DIY articles and so forth.
Mike's got the right idea... so if you can share your wisdom on all things Prelude specific, please do.
:: HAN Integra FAQ:
Old 07-04-07, 05:40 PM   #5
DarkStarr
First or last baby!
DarkStarr's Avatar
Send a message via AIM to DarkStarr
I purchased my Prelude two weeks ago, any time I repair/replace anything I will make a DIY for others to look at. As I learn more about the vehicle I will be able to chip in some knowledge
DarkStarr is online now   Reply With Quote
Old 09-05-07, 12:56 AM   #6
Mkazm83
Snapping bolts
Mkazm83's Avatar
Does anyone even read this?
Old 09-05-07, 12:59 AM   #7
Samson
chris is the devil
Send a message via AIM to Samson
Quote:
apparently you do
05 Acura RSX Type-S
Beater-
Samson is offline   Reply With Quote
Old 11-22-07, 11:27 PM   #8
brand_new_lie
just started on here. I recently blew my h-23 in my 93 and had to get another one.
im sure it's a given but h-motorsonline.com is the place to go, esp. if you just feel like going with the h22
brand_new_lie is offline   Reply With Quote
Old 04-12-08, 09:25 AM   #9
V101_ATA
plenty of thorough articles and FAQ's here:
http://www.honda-tech.com/zerothread/2168311
http://preludeuk.forumup.com/viewfor...orum=preludeuk
V101_ATA is offline   Reply With Quote
Old 06-04-08, 06:02 PM   #10
subydoored
hmm were to start oh ya info how about i start with block info
If I leave something blank and you have the information/specs plase post it up and I will edit this post and ad the new additions to the thread.
Blocks
Block Type
H22A4 Block = Open Deck
H22A block = Closed Deck
H23A block = Open Deck
H23A1 block = Closed Deck
F22 block = Open Deck
F23 block = Open Deck
F20B block = Open Deck
Deck Height
H22A4 Block = 8.643
H22A block = 8.643
H23A block = 8.643
H23A1 block = 8.643
F22 block = 8.643
F23 block = 8.643
F20B block = 8.643
Bore
H22A4 Block = 87mm/3.425
H22A block = 87mm/3.425
H23A block = 87mm/3.425
H23A1 block = 87mm/3.425
F22 block = 85mm/3.346
F23 block = 86mm/3.385
F20B = 85mm/3.346
Note:
Due to various available piston diameters (A/B) actual bore diameter may vary
Rods
Length
H22A4 = 5.633
H22A = 5.633
H23A = 5.572
H23A1 = 5.572
F22 = 5.572
F23 = 5.551
F20B = 5.709
Width
H22A4 = .935
H22A = .935
H23A = .935
H23A1 = .935
F22 = .935
F23 = .780
F20B = .935
BE Bore
H22A4 = 2.008
H22A = 2.008
H23A = 2.008
H23A1 = 2.008
F22 = 2.008
F23 = 1.890
F20B = 1.890
Pin Bore
H22A4 =
H22A = .8649-.8654
H23A =
H23A1 = .8649-.8654
F22 = .8649-.8654
F23 = .8649-.8654
F20B =
Pistons
Bore
H22A4 = 87mm/3.425
H22A = 87mm/3.425
H23A = 87mm/3.425
H23A1 = 87mm/3.425
F22 = 85mm/3.346
F23 = 86mm/3.385
F20B = 85mm/3.346
Note:
actual diameter may vary depending on code of piston (ie, A B)
Compression Height
H22A4 = 1.221
H22A = 1.221
H23A = 1.203
H23A1 = 1.203
F22A1 = 1.203
F22A4 = 1.203
F23A1 = 1.181
F20B = 1.221
Dome Volume
H22A4 =
H22A =
H23A =
H23A1 =
F22A1 =
F22A4 =
F23A1 =
F23A4 =
F23A5 = -18cc
F20B =
Wrist Pin Diameter
H22A4 = .866
H22A = .866
H23A = .866
H23A1 = .866
F22 = .866
F23 = .866
F20B = .866
Crankshafts
Stroke
H22A4 = 90.7mm/3.570
H22A = 90.7mm/3.570
H23A = 95mm/3.740
H23A1 = 95mm/3.740
F22 = 95mm/3.740
F23 = 97mm/3.818
F20B = 88mm/3.464
Main Journal Diameter
H22A4 = 55mm
H22A4 = 50mm (1997 Only)
H22A = 50mm
H23A = 55mm
H23A1 = 50mm
F22 = 50mm
F23 = 55mm
F20B = 55mm
Rod Journal Diameter
H22A4 = 1.888
H22A = 1.888
H23A = 1.888
H23A1 = 1.888
F22 = 1.888
F23 = 1.771
F20B = 1.771
Cylinder Heads
Combustion Chamber Volume
H22A4 = 53.8cc
H22A = 53.8cc
H23A = 53.8cc
H23A1 = 50cc
F22A1 = 50cc
F22A4 = 50cc
F23A1 = 50cc
F23A4 = 50cc
F23A5 = 50cc
F20B =
Intake Valve Diameter
H22A4 = 35mm
H22A = 35mm
H23A = 35mm
H23A1 = 34mm
F22 = 34mm
F23 = 34mm
F20B = 34mm
Exhaust Valve Diameter
H22A4 = 30mm
H22A = 30mm
H23A = 30mm
H23A1 = 29mm
F22 = 29mm
F23 = 29mm
F20B = 29mm
Head Gaskets
Bore
H22A4 = 88mm
H22A = 88mm
H23A = 88mm
H23A1 = 88mm
F22 = 86mm
F23 = 87mm
F20B = 86mm
Thickness
H22A4 = .026
H22A = .026
H23A = .026
H23A1 = .026
F22 = .026
F23 = .026
F20B = .026
Note:
Gasket thickness measured after crush
Bearings
Main Bearing Thickness
Blue: 2.013 - 2.010mm / 0.0793 - 0.0791
Black: 2.010 - 2.007mm / 0.0791 - 0.0790
Brown: 2.007 - 2.004mm / 0.0790 - 0.0789
Green: 2.004 - 2.001mm / 0.0789 - 0.0788
Yellow: 2.001 - 1.998mm / 0.0788 - 0.0787
Pink: 1.998 - 1.995mm / 0.0787 - 0.0785
Red: 1.995 - 1.992mm / 0.0785 - 0.0783
Rod Bearing Thickness
Blue: 1.510 - 1.507mm / 0.0594 - 0.0593
Black: 1.507 - 1.504mm / 0.0593 - 0.0592
Brown: 1.504 - 1.501mm / 0.0592 - 0.0591
Green: 1.501 - 1.498mm / 0.0591 - 0.0590
Yellow: 1.498 - 1.495mm / 0.0590 - 0.0589
Pink: 1.495 - 1.492mm / 0.0589 - 0.0587
Red: 1.492 - 1.489mm / 0.0587 - 0.0586
Main Bearing Width
H22A4 = .784
H22A = .784
H23A = .784
H23A1 = .784
F22A1 = .784
F22A4= .784
F23A1 = .784
F23A4 = .784
F23A5 = .784
F20B = .784
Rod Bearing Width
H22A4 = .762
H22A = .762
H23A = .762
H23A1 = .762
F22A1 = .762
F22A4 = .762
F23A1 = .609
F23A4 = .609
F23A5 = .609
F20B = .762
subydoored is offline   Reply With Quote
Old 06-04-08, 06:04 PM   #11
subydoored
H series tranny info and codes
Prelude
M2A4 - JDM 4G
M2B4 - JDM 4G LSD
M2F4 - USDM 4G
M2U4 - JDM 5G Type-S ATTS/USDM Type-SH ATTS
M2Y4 - JDM/USDM 5G Base
M2Z4 - JDM 5G SiR S-Spec/JDM 5G w/ LSD option
Accord
T2T4 - JDM Accord SiR-T (F20B) LSD
T2W4 - JDM Accord Euro-R LSD
U2Q7 - EDM Accord Type-R LSD
Satan owns.
Added 2004/02/09 Full Gear Ratios
M2A4 - 3.307 - 1.950 - 1.360 - 1.071 - 0.787 - 4.266
M2B4 - 3.307 - 1.950 - 1.360 - 1.071 - 0.787 - 4.266 LSD
M2F4 - 3.307 - 1.950 - 1.360 - 1.071 - 0.870 - 4.266
M2U4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 ATTS
M2Y4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266
M2Z4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 LSD
Accord
T2T4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 LSD
T2W4 - 3.285 - 2.090 - 1.481 - 1.071 - 0.812 - 4.266 LSD
U2Q7 - 3.285 - 2.090 - 1.481 - 1.071 - 0.870 - 4.266 LSD
Old 06-04-08, 06:41 PM   #12
subydoored
h23 manual tensor conversion
http://www.honda-acura.net/forums/sh...42#post3927442
Old 07-09-08, 10:07 PM   #13
Mass_D
for those of you who have a 92-96 2.3 DOHC....
http://www.hondahookup.com/manuals/?...92-96_lude.pdf
for the record, you can find the manual for any Honda here, so I'll probably re-post the link in the general area
Mass_D is offline   Reply With Quote
Old 08-31-08, 09:12 PM   #14
shah2105
Hello to all Luders,
This link is very useful for 4WS problems:
http://www.honda-tech.com/zerothread/886363
shah2105 is offline   Reply With Quote
Old 10-21-09, 03:37 PM   #15
codye3m
codye3m's Avatar
here is some downloadable manuals to help yall, http://www.spoonertuner.com/manuals,
i know some things about 5th gens, so if you have questions ask
codye3m is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
