DIY Fix: Squeaky top strikers/latchers
Old 02-19-2007, 07:55 PM
Quick Silver
Vroom Vroom..!
Quick Silver's Avatar
Default DIY Fix: Squeaky top strikers/latchers
As the strikers become older they star to get worn due to the constant friction between them and the top's latches.
The wear of these parts creates play between the latch and the striker and this causes a squeaking sound that its anoying enough to drive anyone insane making noise even while taking the slightest of turns (this is specially embarasing if you have a passenger with you )
You can always buy new strikers or try swaping them from one side to another to give the latches a fresh surface to rest against OR...
you can do this:
go to your local Home Depot and buy yourself a box of #31 O-rings from the plumbing section (by the faucets)
they should look something like this:
Dimensions are: O.D: 9/16" I.D: 5/16" x 1/8"
Outside Diameter: 9/16"
Inside Diameter: 5/16"
then install them over the latches' pin as shown:
(you can can as an option use a bit of superglue to fix them against the pre-existing rubber stopper)
this will create a better seal between the latch and the striker preventing them form rubbing and making that horrible squeaking noise
Best part of all the O-Rings are $1.97 for a box of 10 :thumbup:
Took the car around some tight turns, in and out some driveways where previous to the washers the top would have squeaked and got NO squeaking
I'll post updates as of how they washers will hold up after a few days
Old 02-19-2007, 08:01 PM
Neat Mine does that..
Thanks
If you have a fix for the squeaks near the passenger door (On the soft top itself) not the passenger seat belt... Please share h:
Old 02-19-2007, 08:42 PM
Quick Silver
Vroom Vroom..!
Thanks
Sorry I haven't experienced any squeaking coming from that area as of yet (knock on wood)
maybe try using some shin-etsu grease to dress/condition all rubber components on the top?
Old 02-19-2007, 08:53 PM
Thought about it, but it's bearable for me for now h: I'll use your method for my catchers though
Old 02-19-2007, 08:59 PM
Nelson
Administrator
Nelson's Avatar
Very nice
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old 02-20-2007, 10:45 AM
kd5dbl
kd5dbl's Avatar
There is also a Honda Service Bulletin about noisy strikers with a slightly different fix you might want to look in to. It made a big difference in mine...
http://www.s2ki.com/stor/library/TSB/a03-023/index.htm
Old 02-20-2007, 04:54 PM
Quick Silver
Vroom Vroom..!
do you have any more info on the service buletin? maybe the TBS#
Old 02-20-2007, 05:54 PM
evolution
早晨好, 先生們!™ 粉腸+ 春袋
evolution's Avatar
Sweet thanks mine has creaked since day one. I swapped it out the entire latch at Honda a few years ago, $200 under warranty. Since warranty is done it's been annoying me ever since!
Old 02-21-2007, 11:27 AM
HatchVX
Driving a Turbo 2L Terror
HatchVX's Avatar
the service buletin has you replace the soft top strikers with hard top ones.
Old 03-08-2007, 09:41 PM
reech-around
RIP Woong.
reech-around's Avatar
I did this a few weeks ago and it made a HUGE difference. my hardtop was used so the latches were down. excellent and cheap mod :thumbup:
