HELP! How to Replace a Civic Trunk !!
:wtc:Someone stole my spoiler off my 2000 Civic I just bought another trunk with a spoiler someone I found off Ebay and I wanted to switch out the trunks since I now have holes in it as they tore it off...... I was wondering if any 1 knew the cost of labor for putting the other trunk on or can you do that yourself if so how is it done? ???
nah i havent look but my old spoiler had the brake light attached , so does this one , if they ripped it off would I need new wires? or is there a way to to re connect them?
Re: HELP! How to Replace a Civic Trunk !!
Yea I knw but I am a girl and I dont fix cars but I heard U cld change your trunk your self I didnt know if there were any special tools I check out my trunk last nite and saw the 4 bolts and a wire now my thing is how do you remove the wire for the brake light it looks like it goes thru a hole in the trunk and I dnt see where it connects to ?? how to I remove the wire to reconnect eith out damagin it??
it's not hard just 4 bolts and you have to disconnect the trunk opener thing and take out the cable and wires. then just put everything back together the same way. you will need 10mm socket and 8mm socket
