Driver Door Lock Actuator
How's it going. I was wondering if anyone can tell me if a driver door lock actuator off a 1991 Legend Sedan will work and fit on a 1992 Legend Coupe LS.
My coupe's driver door lock actuator is acting up and I found a used sedan door lock actuator, but neither the seller or dealer knows if it will work in my coupe.
You're probably not looking anymore but in case you are, I don't believe they are the same if you are talking about the whole assembly. However, it is pretty easy to pull out and if you're not paying much it might be worth the try. Here is a pic of a coupe's assembly for reference.
