clutch slipping? Replacement costs?
I left my car sitting up hill for about 2 days, and now the clutch engagment is really early, the peddle feels like it is sticking a little and is slow to return once i push it in.
would a Exedy clutch kit be all that I would need?
EXEDY Pressure Plate
EXEDY Clutch Disc
Release Bearing
Pilot Bearing
Alignment Tool
How difficult would it be to replace? How much should I expect a shop to charge for replacing it? (im in gainesville fl)
Im in a 92 Civic HB that was swaped (several years ago) with a b16a and went from Auto to manual, so I don't know where my clutch parts came from.
So if this kit is a replacement, then do I just need one for my engine type?
EXEDY Clutch Disc
Release Bearing
Pilot Bearing
Alignment Tool
Still here... sorta...
How to: https://www.honda-acura.net/forums/s...d.php?t=139802
You will need the kit for the engine, not for the car.
Exedy makes a good kit and the items listed will be all that you need.
EXEDY Clutch Disc
Release Bearing
Pilot Bearing
Alignment Tool
EXEDY Clutch Disc
Release Bearing
Pilot Bearing
Alignment Tool
Where do you live at. Maybe I could be of some assistance.
If you have any decent tools, it's not really a special socket, just a 12 point 10mm socket for the clutch PP and a 17mm 12 Point socket for the flywheel bolts.
I did my first clutch with my mechanic, (mainly me doing most of the work, but I have done numerous since then.) I can do it with my eyes closed now.
