bumpy ride on stock springs/koni yellows
so i have a 99 si and at first it had stock shocks and s-tech springs. I didn't like the drop on it when I bought it so i replaced them with eibach pro-kit springs and koni yellow. I didn't like the drop, I felt they were on par with the s-tech and the ride was harsh.
so now I am riding on stock springs with koni yellows and the ride is still harsh, every bump can be felt.
is this a problem with the shocks or a part of the suspension, or would the springs play a big role?
as for springs, I want something with not a giant drop but rides smooth. I was thinking HR OE or I have heard some good things about type R springs
any help/opinion would be great
what are the settings on the koni yellows? hard, soft? if its on full hard, ride is gonna be really rough. and lowering springs is gonna be a bit rougher than stock springs
i have tried everything in between full soft to full hard. right now its on full soft and its a little bit better, but still harsh. I still feel bumps but not as bad as full hard
Banded
Weird, try getting some coilovers, that way you can always adjust ride height. I have tokico blue with ground control coilovers, and that thing is slammed and rides better than stock.
GC last time I checked probably run ~350-400ish right? I was looking into GC and remembered that it was better due to the fact that you can get custom spring rates and you don't have to worry about spring compressors or the sort when you want to change out the springs
are they hard to install?
If you want a soft ride, get a Benz. But no, really, if you want a soft ride, you can get the Tein Cruising master. They are meant for th nicest ride possible. But usually when you buy performance shocks, they are meant for performance, not ride quality. I had Koni Yellows with GC coilovers on my car, and I felt the bumps too. But I like my ride to be stiff. It handles better.
a M3 is in the works
I expect the ride to be bumpy as there really is no perfect under 20k car that has perfect suspension where it glides..but how nice that would be.
i just wanted something that doesn't quite take the full impact of the bump, currently my friends 88 gti rides better than my 99 does h:
You shouldn't need a spring compressor to change out your springs. The only time you need one is when you are removing the stock springs for the struts.
Honorary Moderator Alumni
Koni Yellows are twice to three times stiffer than stock shocks. Which is why your ride is harsher.
Autocross Help Page
Autocross Help Page
