1992 honda accord losing power
Old 10-27-2006, 07:45 PM
Ralph2112
Ralph2112's Avatar
Default 1992 honda accord losing power
My 1992 honda accord is losing power if i let go of the gas it does fine then it loses power again i have to keep doing that until it works itself out or if i keep the gas pedal down to try to maintain speed it spits and sputters until the check engine light comes on them it is fine PLEASE HELP
Old 10-28-2006, 11:23 AM
Cousin It
Cousin It's Avatar
If you have a CEL start by retrieving the code from the ECU.
Old 10-28-2006, 11:50 PM
mycb7com
mycb7com's Avatar
What make, how many miles, manual or auto? Date of last tune up?!
Old 10-29-2006, 09:34 AM
rags2riches
rags2riches's Avatar
you may have a loss in compression. there's additive for your crankcase for taht. or your fuel filter may be clogged. if you are running the stock filter maybe its time to change it.
Old 10-29-2006, 11:33 AM
98CoupeV6
lots and lots of fail
98CoupeV6's Avatar
:rofl: what's that, hot glue sticks?
Old 10-29-2006, 12:38 PM
rags2riches
if you don't know what additives to restore compression then you can ask the Mechanic you paid to install your #2 tranny and #2 & #3 alternator. hello.....are you still there? or is you Vtech off the (phone) hook.
Old 10-29-2006, 01:51 PM
98CoupeV6
98CoupeV6's Avatar
did it all myself, thanks.
explain to me what magical additive fixes a head gasket or piston ring for more than a couple hundred miles. band aid on a broken arm. don't even talk to me about not doing work on my car if you think half assed $15 solutions fix major engine mechanical problems.
Old 10-29-2006, 03:35 PM
Momobile
Mom's shade tree mechanic
Momobile's Avatar
KW Block Sealer
Old 10-29-2006, 04:06 PM
Ralph2112
Ralph2112's Avatar
Default ecu codes
My 1992 handa accord is losing power
I got some codes from the ecu.
(1) code 14
(2)code 1,2,3,7,8
The second set of codes have a 2 second pause between each one I am not sure how to read them can anyone explain.
Old 10-30-2006, 07:35 AM
TypeG
TypeG's Avatar
(1) code 14
(2)code 1,2,3,7,8
http://www.cb7tuner.com/vbb/showthread.php?t=21259
later.
