97 Civic MES Connector
Ok, had airbags replaced. They didn't reset SRS light (it wasn't a honda dealer that did the work, they were the ones my insureance wanted). Figured I do it myself and if that didn't work, then I'd take the time off, make them check it out.
here's the thing. Found the MES connector. Dang thing will not let go of the fuse pannel. won't come out of the dummy holster. didn't seem to be any clips or releases. I'm afraid I'm going to tear the darn fuse system out of the dash, or bust it off.
Any ideas.
dreyerwolf@yahoo.com
Any ideas.
their are 2 yellow connectors on some models one has a clip you push down comes out easy thats the one you want their is another that is bigger and you have to pull on the box that is the rong one don't short that one.there is info in the diy on this site.
there seems to be only one on my model. It's even labeled on the fuse "directory" as SRS. I'm assuming since it's big and yellow and labeled, that it's the one I'm looking for.
They weren't deployed, they got stolen. Not sure if it results in the same situation. I just though I'd try and reset it before having to take time off from work and take it back to the shop that installed them. I don't have much faith in them at this point.
you were right, there are 2 of them (yellow). I was trying to pull the lower (and bigger one). No way that one is coming out. There is one hiding further up on the board behind a whole cluster of wires. looks like it has the easy clip you described. As I look at it, it has 3 wires running to the connection.
Would someone like to clarify if that's the one I want before I disconnect it?
thanks.
thanks.
