Safe to run stock b16 retainers to high rpm
Hi guys, I have a b16a2 engine which I will be installing ctr cams with jun valve springs, are the stock retainers safe use up to 9000 redline? thx
Banded
Some of the more experienced people on here were saying that those are the same all around the vtec b series... Just what I heard. If you want upgrade, go with skunk2 or toda.
what about your ECU can that handle the increased RPM?
Can your crankshaft handle that extra revving?
I know you can make your car rev higher but the question is can the parts handle it. ( crankshaft, pistons, etc.. )
On permanent hiatus
ITR retainers are identical to B16 retainers. Aftermarket retainers are cheap enough, so it wouldn't hurt to upgrade them. I don't think you really need them, though.
been there done that
you do not need to rev that high with ctr cams. oem retainers are fine with those cams. i'd be worried about those valve springs you want to run though. they might be too stiff for the cams.
