Headgasket??
warm butter on toast
Headgasket??
I noticed the front of my block on the driver's side was wet with coolant today. I did a compression test and of course because I have brand new rings in there Every cylinder was at 275/274 psi. I'm not getting any coolant in my oil, or oil in my coolant. I'm not getting any smoke out the exhaust and I'm not losing a noticable amount oil or coolant. And I didn't get any over heating in or out of boost after driving for about 2 hours.
I got a copper sprayed MLS headgasket with ARP head studs.
I wiped the area down and it came back after some hard driving.
Anyone got a diagnosis?
Banded
Are you sure thats where its coming from? For me it leaker from somewhere else to the headgasket area and it looked like the headgasket was leaking. Thats probably not it for you, but just in case h:
possible leak from one of the coolant hoses?
turning u inside out
its possible its coming from the head gasket. mine didnt seal all the way near where the tranny bolts to the block. im gonna just change it over the winter when im doing my other lil projects
Yeah... I inspected and put new clamps on all the hoses and replaced the hoses that were leaking.
Yeah. It doesn't seem like a hose but as long as it's not fucking up my oil or compression I'm only gonna be driving it for another month tops. Then it's time to bust out the winter Jeep.
Banded
Not meaning to hijack or anything, but why do you guys use copper spray on the headgasket? I didn't, is that going to be a problem? :noes: (none of our cars have leaked tho...)
Your Powder Coater
it's an extra helper for the head gasket to seal, mine seems to have been holding up really well with it. I've talked to some others & they seem to be firm believers as well.
That's probably your problem. Honda OEM MLS head gaskets are NOT supposed to be copper sprayed; they should be installed dry. The spray creates a slicker surface for the head and block mate with, which will weaken the seal substantially.
Another possibilty is head lift, but I think if it was head lift, you'd have other symptoms.
Anyway. I have no clue whats up with it. My temp never goes above 1/3 on the temp gauge and I've been beating the shit out of the car. Hopefully it lasts till mid November.
