Car Stales at Low RPM
Hello,
i have a Honda Civic 1992 Single Carb 5 speed Manual car, i started having problems with it a couple of days when i stop at a set of lights my car would just stale. When i drive all seems OK.
I thought it could be a problem with the Idle circut in the Carb, so i took out the carb, and started cleaning the Jets and all the parts in the Carb. Put it all together, The float is all good. Started the car and it runs OK, as soon as the choke turns off the car idles but makes a pup pup nosie in the exhaust.
I can't seem to fine what the problem is, i checked to make sure there is no air leaks, Do you think i haven't cleaned the Carb correctly?
Thanks
Thanks
Yep it's a Carb not Fuel Injected
I took the carburetor off yesterday and found that one of the diaphrams had a small hole in it, which means i have an air leak somewhere might try and find it later tonight
