Go Back   Honda-Acura.net > Auto Forums > CL, TL, & Vigor
Thread Tools Display Modes
Old 10-11-06, 03:31 PM   #1
daveander
93 vigor engine problems
I just got a 93 acura vigor. It runs well most of the time, but sometimes the check engine light will come on and the automatic transmission won't shift into the next gear. The light will come on sometimes when I am stopped at a light, and then I have to shift into neutral and restart it. I checked the dtc codes and it flashed a 4, 8 and a 9. I'm guessing that is three different one digit codes. The codes are:
4 Crankshaft Position Sensor
8 TDC Sensor (Top Dead Center)
9 CYL Sensor (No. 1 cylinder position)
as the codes.
So what would that mean? Are three of the sensors broken, or is it something else? Please help. I love this car, but I don't want to put a lot of money into it, so if it is something I can fix myself I want to try that before I take it in.
      Registered and logged-in users don't see this ad!
Register your free account today.
daveander is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-17-06, 01:50 AM   #2
kiwi_vigor
try changing the auto trans fluid, that will most likely fix it
kiwi_vigor is offline   Reply With Quote
Old 11-11-06, 11:36 AM   #3
aspen007
This may sound strange, but here's the likely answer.
Your alternator is bad and needs replacement.
The faulty alternator gives out voltage spikes which makes the computer think one of the sensors is bad (ie. crankshaft position sensor- Code 4) and puts the engine in "limp mode" which in turn limits the engine's rpm to about 3000 rpm and causes tranny shifting problem.
To test the alternator, drive the car with no accessories on. The check engine light should not go on. Now turn on all your electrical stuff (lights, blower, defroster) and the check engine light should come on. If it does, replace alternator.
aspen007 is offline   Reply With Quote
Old 02-06-07, 01:53 PM   #4
k2robb
'92 vigor hesitation
Hi,
I have just been through this.
When I first start my car, it runs fine. After a few minutes, the engine light goes on and it starts hesitating at 3000 rpm so I back off the gas pedal a bit, let it change gears, ease on the gas pedal again, then do the same for the rest of the gears. When I stop at a light it runs rough and sometimes stalls.
Sometimes, I can turn the car off, restart it and be able to drive normally again for a few minutes.
I have had it to 3 garages including the dealer and have spent $1,000.
This a list of the components that have been changed:
1) distributor
2) crank sensor
3) fuel filter
4) computer
NONE of these worked even though the Acura dealer swore it was a computer problem.
Another mechanic researched bullitin boards and found this problem to be common and that it is the fault of the alternator. Even though the alternator light doesn't come on (it is still charging the battery). The alternator rebuilder showed me a schematic which shows the choke running from the alternator!!!(either way, the alternator seems to control or affect many functions that are not obvious).
Anyway, he changed the alternator and now it runs great.
k2robb is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
