what pistons to raise compression in JDM B16A?
what pistons is out there that would raise my JDM B16A compression of 10.4 to somewhere in the 11.5 range?
thanks in advance!
thanks in advance!
been there done that
if the head hasnt been milled and your running an oem 3 layer headgasket, ctr pistons would put you at 11.9:1. or you can go with aftermarket forged pistons to put it at wherever you want.
my plans are to get near the highest compression with pump gas. i dont plan on going bigger on the bore so compression would be the start in the motor process. then im gonna match a cam to the compression profile. but i mainly want to stay away from boring out the cylinders.
btw where can i purchase higher compression pistons? ive search all over online for high compression B16 pistons but the highest i find are stock compression but forged.
