overheating when i boost
Im having problems my car overheating, i dont have any problems untill i start hitting boost, driving with out boosting i have no issue, about 10 sec after i boost the temp starts to rise, and will start overheating. anitfrezze is pushed out to my overflow and not returned,it steams out the top of the overflow where the tube comes in from the rad. Any thoughts on what this could be?
I def agree with the possibility of the head bolts stretching, but where's all the heat coming from?? It should not be boiling over...... If you are simply pumping cylinder pressure into the water jacket it will blow out the overflow like you're saying but not necessarily get hot.
Correct me if I'm wrong but you're seeing this symptom (temp rising followed by boil-over) several seconds AFTER boosting??
