Bright spot in paint
Someone keyed my car this weekend and I used some heavy duty turtle wax rubbing compound on the area. It left a bit of a bright spot (light horizontal swirl marks)? Is there any way I can fix this easily or at least make it look a bit better?
Let me know if there is anything else I can help you with. For future reference, never use rubbing compound on your paint as a goto step there are much safer measures to take before using a compound such as the polishes i recommended.
Sincerely,
George @ Detailed Image
should i apply vigorously with the "higher grit" rubbing compounds? will it damage the paint at all?
i didn't particularly press very hard with the heavy duty turtle wax compound, as i did know there was some chance of taking off the paint completely somehow.
