parking on a hill with an at
Swollen Member
I don't understand why this is even a concern and I don't see why you need to put it in neutral first or even pull the ebrake first. I just press on the brake, put it in park, pull the ebrake then let go of brake pedal.
Originally Posted by oholdeno
i try
hold brake
put in neutral
pull e-brake
let go of brake
put in park
corrections if i'm wrong
hold brake
put in neutral
pull e-brake
let go of brake
put in park
You forgot to mention the turning of the steering wheel, and letting it roll slowly downhill until the wheel touches the curb.
I understand the use of neutral to let your brakes hold your car up instead of the transmission. I think you can just press the brakes, put it in park, pull the e-brake, and then release the brakes. If you release the e-brake, the car will roll an inch before the transmission stops the car (or at least on the MT).
i think he does this because once you shift into D or R it shifts hard.
I see the e-brake will eliminate that instead of pressure being put on the tranny when sitting on a hill.
lots and lots of fail
1 Post
