98 Accord is just cutting off1
My wife's car is just cutting off on her as she is driving down the road. Interstate or city driving it doesn't matter. Didn't know if it was the coil, fuel problems, or cat problems
What else would you like to know. I do have my engine light on and the code is the famous Cat code, but it's been on a long time. This just started doing this the past month or so.
lots and lots of fail
1 Post
Call the dealer and they'll be able to tell you.
http://www.autorecalls.us/aut-04/rec...ord/40221.html
That's it right there.
Recall Date:
2002-05-16
Summary:
ON CERTAIN SEDANS, COUPES, HATCHBACKS, AND SPORT UTILITY VEHICLES, ELECTRICAL CONTACTS IN THE IGNITION SWITCH CAN DEGRADE DUE TO THE HIGH ELECTRICAL CURRENT PASSING THROUGH THE SWITCH WHEN THE VEHICLE IS STARTED.
Consequences:
WORN CONTACTS COULD CAUSE THE ENGINE TO STALL WITHOUT WARNING, INCREASING THE RISK OF A CRASH.
Recall Date:
2002-05-16
Summary:
Consequences:
If the recall isn't it (or the ignition switch which you might can check by jiggling it around while parked))...look for the obvious stuff like a corroded or bad battery or chassis ground....even the pos side....loss of battery connection.
