S2000 Short Shifter!!!
Old 05-29-2006, 12:01 AM
hot_kenneth_hot
S2000boostaholic
hot_kenneth_hot's Avatar
Default S2000 Short Shifter!!!
I know the S2000 has a short throw to the gears, but has anybody seen a short shifter on the market for the S2000's???
Old 05-30-2006, 04:14 AM
shivers
Moderator Alumni
shivers's Avatar
Comptech is working on one. Axial Flow has one out available through www.ricks2k.com ... you can read reviews of it on s2ki.com.
2005 s2000
Old 05-30-2006, 10:02 AM
evolution
早晨好, 先生們!™ 粉腸+ 春袋
evolution's Avatar
Isn't the stock one good enough? The throws are so short and close already.
Old 05-30-2006, 10:55 AM
That's what I thought.... I haven't heard anyone really replacing the shifter :dunno:
Old 05-30-2006, 12:57 PM
Buyimports2
Buyimports2's Avatar
I'm pretty sure you can buy them but I think it would be pointless because the stock one is already so short.
Old 06-02-2006, 06:24 PM
jlammy
w00t
jlammy's Avatar
Yeah. It is pretty short already. I don't think I would want something shorter than that :dunno:
Jimmy
Team B.O.B.™ - Ballaz on a Budget
R.I.P Huan Vo 11-19-2008
Old 06-02-2006, 09:16 PM
dubcac
I
dubcac's Avatar
No need. Even the integra doesn't need one, and the s2000 is shorter than that.
Old 06-05-2006, 11:58 AM
Phateless
S2K compatible
Phateless's Avatar
talk about redundant.
Old 06-22-2006, 06:16 PM
killers2k
killers2k's Avatar
its your car buy what you want for it. have fun with it make it unique to your style. pleasing our likes will never make you happy with your car.
Old 07-12-2006, 06:18 AM
LateApex
Track Day Club
LateApex's Avatar
I generally agree.
You can take almost an inch off of the stock height by using a countersunk shift knob. I've got a couple of those in the garage and they work very well. Using a countersunk knob still leaves most of the feel that you need to keep in order to "read" good shifting practices on the street or on the track.
There may be a true "short shifter" out there for the S2000, but I have not seen it. A short shifter usually lengthens the the shift lever from the fulcrum down to the shift ball. That permits more travel below the fulcrum for a any lever movement above the fulcrum.
This is usually accomplished by raising the fulcrum or dropping the shift mechanism to make room for the lower part of the lever. With the S2000, you can't lower the shift mechanism because it's already sitting on top of the transmission without any linkage. You can't sensibly (at least for a street car) raise the fulcrum point because you would need to raise the shifter above the top of the transmission tunnel.
I suggest that you try a countersunk knob first. You may find that you're happy with it.
